Fuel System question for dummies
Old 09-11-2006 | 10:59 AM
riversidediesel's Avatar
I recently bought some Stage 3 edge injector nozzles for my 02' dodge 4x4. I heard from one of my roomate's friends that if I put them in without having a perfomance pump, my truck is likely to go haywire. Is this likely to happen? If so, where can I find a good one without breakin the bank.
2002 Dodge 3/4 ton 4x4
Edge EZ, Bully Dog stage 1 intake, Banks power elbow, turbo silencer ring MIA, 4 inch exhaust system, aeroturbine muffler, 5x22 inch tip
Old 09-11-2006 | 11:15 AM
RowJ's Avatar
Welcome to DTR!
I assume your concerned about low fuel pressure??
Just monitor your gauge, but I would not expect a serious problem with just those injectors. Don't know your Bully Dogs HP level but if you keep FP over 8 psi with your throttle, you'll find out if you need after market fuel pump or not. You won't hurt anything trying it out!
Do a search on installing tips, if you have not done it before. There are some important Do's & Dont's, from what I hear.
Good Luck
RJ
Old 09-11-2006 | 04:06 PM
kipo's Avatar
You could go with a Vulcan big line kit and a holley Blue tied into the hard lines back by the tank for $200 or so. I have Scotty fitting and a Blue and see 24 psi @ idle and 20 @ WOT!! Vulcan and a Blue should put you close to that.
Old 09-11-2006 | 11:48 PM
Where could I find do's and don'ts on installing injector nozzles? I've looked and looked everywhere.
Old 09-12-2006 | 07:43 AM
RowJ's Avatar
Do a search on this site! You have to search through some unwanted stuff but.... you learn a lot too!
I typed in 'injector tips', under Search and came up with this thread in about 2 min!
https://www.dieseltruckresource.com/...=injector+tips
RJ
paidoffpit
02-23-2008 10:55 AM
SHARPMACHINE
08-02-2005 11:32 PM
rico334
10-08-2004 11:53 AM
dcwm
08-03-2004 08:34 PM
lezmark7
03-24-2003 09:54 PM
Quick Reply: Fuel System question for dummies
