Fuel system mods and Diablo Sport ?
Newb to CTD's and new to the site, so kid gloves plz ![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
Just purchased an '01 Ram 2500 CTD, w/180k miles; new VP and LP installed by prev. ownr about a month ago (I got the receipts). It has a K&N mounted directly to the front of the turbo, 5" stack exhaust, Diablo Sport, stock fuel system, a fuel pressure guage. Fuel pressure runs about 9-10psi when its cold, about 7.5psi @ 70mph. Will dip to 6psi if I do around-town driving (maybe from heat soak?), WOT doesn't seem to change it --> Time for a fuel system and guages, methinks.
Questions:
- FUEL: It looks like a Glacier or Vulcan are the only pre-built options for big lines & dip tube. I've searched and read several threads on this. There doesn't seem to be a consensus about brands, or methods. Suggestions welcomed ! My theory is to do it right the first time! Does that mean two pumps? IMO, pumps and fittings are cheap - compared to VP's!
- CHIP: Can I, or How do I interface with the Diablo Sport? According to Diablo's website, its a single setting unit for the '01's.
Questions:
Well you can do some different options for fuel upgrades........it all depends on how much you wanna spend. You can get a FASS system which most here recommened, but they are pretty pricey. Vulcan is a nice setup as well and is a little bit cheaper.
I am running Bully Dogs fuel system upgrade......which consists of a Holley Blue pump and bigger lines to the VP. It works awesome and total with shipping I spent less than $300 bucks for it.
Everyone has there upsides and downsides.......I can't speak from experience with any of the other systems cuz I've never had them.....but hopefully some other guys will chime in and help out!!
~Nick
~Nick
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
Other mechanical systems availible are called rasp and mitusa. There are plenty of electronic options also, but you *said* do it right =P If you want cheap and easy instead vulcan and walbro or even the bully dog kit mentioned above are good options.
bigcat83
02-01-2009 09:17 PM
MegaMagoo3500
03-27-2008 09:50 PM
Dodgewincity
18
01-24-2008 10:42 PM
hottapper1
05-27-2007 04:40 AM
CDoskocil9
16
04-02-2007 02:18 PM
