Fuel pumps: can I use any other type?
so I just got my old truck back and it appears that the lift pump is toast again, ( just installed a replacement carter a year and a half ago. any way my guage reads 10 at idle and 0 at barely any throttle, ( kinda strange, but oh well
my question is can I get a holley or something cheaper than a Airdog that will work with my stock filter and not break this quick? I am not opposed to adapting something if it is diesel compatible, thanks in advance,
and yes I will mod it but for now I just need it to be drivable
I have a Holley blue on mine. Been a good pump for two years now. When the taxes get back to me this will be next.
http://www.dodge-diesel.org/fubomelipusy.html
A good solution that will work with your stock filter is the FASS HPFP or Pureflow Raptor.
Just no filtering capability, but you do get fuel pressure control, upgraded lines, relay harnesses,and all the other components to hook up to your stock filter.
As always, I would not install any pump without addressing the stock fuel module and I would add a DrawStraw I for stock non in tank pump modules and a DrawStraw V for the in tank variety.
Dave
Dave
X2 this is an easy to work with quiet, reasonably priced solution that is much better than a carter/ holley pump.
Install it back close to the tank and it will also support more HP in the future for you if you decide to go that route later. Be sure to install a prefilter for long life.
FF5079 is the pre filter screen I use. Do a search on here to find out exactly what you need to do this type of setup. I've had mine on for a couple of years and it works great....
OK you all will laugh but I bought a holley to install because my carter (was not putting out very much PSI as per my guage, well because I planned on installing it(the holley) i put a new filter on well now my fuel pressure is back to where it should be with the carter, so I am taking the holley back, I ultimately want to buy an Airdog just cant afford one right now, so now I can save and put the one on that I want, thanks for all your help I never expected to have a dirty filter as I just replaced it a year ago.
oh, always carry a spare filter in the glovebox!! even if you have a new one on the engine.
also if you relocate your stock pump back to the tank area, it will give much better results. and you will have done most of the work already, when you have to replace the carter in the future.
I have a bullydog big fuel kit. It comes with a bigend pump it works awsome. It has half inch I hose and all the fittings you need to put it on your truck. it was cheep to so that's nice.
The pressure gauge is the best judge of when the filter needs to be changed.
yeah I just repossessed the truck back from a friend who was gonna buy it but gave me no money after a year, so now I have to go over it and see what was neglected. I just put a filter on a year and a half ago. with the carter lift pump. and it has been driven much so I did not think of a clogged filter. now she runs like a top I hope no damage was done to the IP.
I had a rail-mounted Bullydog pump put on. The stock lift pump was gutted to allow fuel flow through. I get 27psi at idle and it never goes below 20 psi at full throttle. And no, I don't have any hard-start problems. I love it!
