Fuel pumps
Fuel pumps
I am tired of changing lift pumps on my truck! I was woundering if the reason I keep having to change them was because of the bigger injectors and the chip or is it because the stock pumps are just junk? I would like to put more of a preformance pump on it to replace the stock one any suggestions. I here a lot about the Fass lift pumps are there any others maybe a little cheeper but as good? thanks Lance
From what I read the lift pumps are bad , but then I read [ less often ] some get a lot of millage out of them .
As much as I've seen [ I do not look much having the 12v ] AirDog is an other , but you may have to put together parts to have something like those for less .
From what I have herd that Fass Fuel has had alot of isues with there systems I have the airdog 150 and happy with that no noise hardly at all and fuel pressure is great.
JJK98CTD
03-29-2009 10:45 AM
05-31-2003 03:28 PM
