Which fuel pump to get?
I'm undecided on what to do for a pump. My fuel pressure is slowly getting lower. I'm down to 11 idle, 10 cruise and 8 WOT. I'm either going with a new stock lift pump or the BD Pusher Pump Kit. I already have Scotty's big fuel line kit. What do you all think?
Originally Posted by MARKY MARK
Anybody out there?
![Confused](https://www.dieseltruckresource.com/forums/images/smilies/confused.gif)
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
I think it's just that this question comes up so often, folks get tired of answering the same question over and over.
If you will do a search for lift pump, LP, FASS, Carter, etc, you will find more information then you can digest.
Originally Posted by crobtex
Sorry, I don't know anything about the BD. I went with the FASS II and larger lines all the way to the IP and have had no problems.
Parts Source
Where are you guys getting all these parts from? I keep reading about larger lines, different lift pumps, gauges, etc but I have no idea where to get them. The closest diesel shop is about a hundred miles from my place out in the sticks. PLEASE HELP!
Sonny
Sonny
Here is info on the FASS: http://www.dieselpp.com/
I think there are several DTR vendors that have aftermarket fuel systems.
Motorpool
Don't forget you can get Scotty's smart fuel system right here in the DTR performance shop. I believe it has everything you need to run bigger lines. I would have purchased it had it been out when I reworked my fuel supply lines.
Mishkaya
Mishkaya
Bradleysram
19
05-12-2009 08:36 AM
MikeBrei
13
10-28-2008 09:25 AM
shrmpboatcptn
02-22-2008 07:40 AM
