Fuel Pressure Sending Unit
I have a manuel fuel pressure guage with a petcock in the line coming from the input to the injector pump. I am going to add an electric sending unit to the line for the Attitude. The sending unit will not be mounted on the injector pump but in the line about 10 inches away from the injector pump.Should the sending unit go before or after the petcock? Thanks.
Thanks for the info Nick. Got er plumbed. Made a bracket that bolts onto the bolts for the brake master cylinder and then attached my home brew fuel pressure manifold with the sender, extra port and valve with hose clamps and a ground.
Mike
Mike
GlennRMK
05-24-2007 11:46 PM
zkhoss
0
04-17-2005 07:39 PM
