Fuel pressure problems/ need help Asap
my friend has a 2000 24 valve that has the juice with attitude. It has been showing that his fuel pressure is low. It will start our running around 15-18 and then will drop sometimes to 0 and give a warning. we have replaced his lift pump several times and runs decent at first but then goes bad. also it has trouble starting now. any advice is appreciated
Obvious answer....
I guess I've just been lucky, I JUST had to replace my LP. But I'm thinking the obvious answer to this question is a RELILABLE replacement LP. I just installed the FASS HPFP 95. ALL in ALL was an easy install EXCEPT getting the stock fuel line separated from the fuel tank.....
I'd say it was pricey, but if he's already replaced a few LP's he could have had a FASS with a life time warranty.
Geno's had the pump to me in 3 days (over thanksgiving holiday).
-Tim
-Tim
What kind of lift pump is it? Is it the old Carter or the new style?
horselady
01-27-2009 12:01 AM
stock03
09-30-2008 09:03 PM
inline6359
20
01-19-2007 10:58 AM
cLAYH
01-07-2007 02:59 PM
