fuel pressure numbers with Holly Red inline with stock LP
Wanted to check and see if the following numbers are OK -- won't blow the seals in the VP44 injection pump. Measuring from the Schrader valve on the VP44:
Before Holly Red:
15 psi idle
12 cruise
9 wot
After Holly Red:
21 psi idle
18 cruise
15 wot
Third LP in 25K miles, so I hope this solves it. Btw -- LP only develops 4 psi at idle through the Holly, when it's not on.
Those numbers OK for the VP44? Thanks.
Before Holly Red:
15 psi idle
12 cruise
9 wot
After Holly Red:
21 psi idle
18 cruise
15 wot
Those numbers should be fine. Make sure you do not lose them over time, and drop too much (under 10 psi at any point). I have no experience with the Holley red, what are the specs? I have a brand new Holley Black, a warranty for a leaky pump. It was always lower psi than my Carter, and cost double the money. .........................................LE
0524VHO
07-05-2008 01:30 PM
Javahjoeo
03-28-2006 07:57 PM
