Fuel Pressure Guage Take off.
I am finally going to do the smart thing and throw a fuel pressure guage in the truck.
Can i just use the schraeder v/v that is on the inlet of the VP44??
if not where do you guys usually run your pressure take-offs??
Jon.
Jon.
Yup, that is where you tap the system for a FP gauge on a 02......it is a -4 SAE 45* fitting but a -4 37*JIC or AN fitting will thread on and not leak - the pressure is far too low to be an issue.....just remove the schrader valve and screw on your fitting and plumb the system with hydraulic hose or a good quality braided hose.
thanks...i am hoping too have it in today...but i am not willing too pull the schraeder v/v, to take it in and size it up, for fear of having it leak all over the place.
Anyone else?? BTW I am installing an electric guage.
I recommend that you use an isolator or needle valve to keep the vp from demalishing your sender...It happened to me. Now,I use a di-pricol gauge mounted on the hood. When my sender was dieing, my f-press. would jump from 20-8-10-11-19-4-ect.... Manual gauges are alot nicer and easier to believe. IMHO
JIM
JIM
4969joes
03-28-2010 06:26 PM
CoolumConst
06-16-2008 11:10 PM
jgiachino
16
07-11-2007 08:33 PM
bigragu
01-24-2006 12:16 PM
