Fuel pressure guage question.......
I getting ready to order a fuel pressure guage and I have one question. Who sells one with EVERYTHING I need to do the installation? I know I will need some kind of mount or pod setup. I've seen several that say I need extra parts and I think that is stupid! I want to get the guage and install it, not have to run around looking for different fittings etc.... Please let me know a brand and part number if you have it. <br>Thanks...
Re:Fuel pressure guage question.......
Check www.wildcatdiesel.com<br>Rod can supply everything needed for an install.<br>I bought my entire gauge set-up for him, and all I had to supply was the truck, the time, and the labor. 8)
Dont forget the banjo fittings..Since you are going to be breaking open the fuel system anyway..might as well help the fuel flow better..<br>Make sure when you order your stuff from Rod...dont let him sell you the new banjo fitting set..you get 4 banjo bolts and one standard grade 8 bolt.... . <br> Now here is what happended..I was in the middle of changing out the bolts in a 99..and found the bolt.. I called Rod(on a Saturday afternoon)..told him what happened..<br> By Tuesday a replacement was at my house..Rod knows how to treat his customers...<br><br>Rick
OldDodgeOwner
02-13-2009 06:13 PM
mytrucksaslug
12-16-2007 02:11 PM
jgiachino
16
07-11-2007 08:33 PM
bigragu
01-24-2006 12:16 PM
