Fuel Pressure Gauges
Old 06-23-2005, 02:43 PM
RAW FUEL's Avatar
I am getting ready to install my gauges also. So you guys are saying that I don't need to install the isolator? Just install the on/off needle valve, then run the tubing to the gauge?
Thanks,
Brian ( Yeah I'm hard headed)
Old 06-23-2005, 03:23 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Thanks,
That's how mine is plumbed.
Old 06-23-2005, 03:33 PM
RAW FUEL's Avatar
Cool deal. Thanks!
Brian
Old 06-23-2005, 04:47 PM
BDR2500's Avatar
Not tryin to steal this thread, but I had a quick question. Is general thread sealer tape from NAPA ok to use to seal up the fittings for my FP gauge and fuel line, or is there somethin special I need?
Old 06-23-2005, 05:42 PM
Shovelhead's Avatar
Teflon tape on fuel fittings in a HUGE No-No.
Little pieces of it can tear loose and get into areas of the Injection system that will not welcome such intrusions.
Pipe Dope or the fuel system sealer from Permatex is a much better option.
Old 06-24-2005, 01:07 AM
BDR2500's Avatar
Thanks, I'll be sure not to use it.
Old 06-24-2005, 04:31 PM
RAW FUEL's Avatar
I have a simple question. You guys that have a on/off needle valve in your fuel pressure gauge line. Where did you get your 1/8 brass needle valves? I've been to all of the auto parts stores, Lowes, building supplies and a plumbing store. Something so simple and you cannot find it. Mind you when you tell them what you are looking for you get a puzzling look or a go away I'm lazy and don't want to help you look. Guess I'll try again at Lowes when I get more time. Any suggestions before I just go ahead and use the isolator.
Brian
Old 06-24-2005, 04:42 PM
Shovelhead's Avatar
I actually bought mine from Grainger.
http://www.grainger.com/Grainger/pro...835462&ccitem=
Other have found them or ones like it at their Auto Parts retailer or local Home store.
Old 06-24-2005, 04:51 PM
RAW FUEL's Avatar
Ok I'll look there.
It seems that some autoparts stores have some stuff and others don't. These around here including Napa did not have a one needle valve. I'll git r dun. Probably later than sooner.
Thanks,
Brian
Old 06-24-2005, 07:28 PM
infidel's Avatar
1/8" needle valves are commonly used on icemakers and swamp coolers.
Any store that has a decent plumbing selection will have them.
I've seen them at Ace Hardware stores.
Old 06-24-2005, 09:38 PM
Mopar1973man's Avatar
Brian
Most NAPA stores... Weatherhead Part number WH6820 - $5.00
I hope this helps...
Old 06-24-2005, 10:04 PM
RAW FUEL's Avatar
Yes sir that does help. Thanks for the part number Mopar1973man. Is this the one you have in your gallery pics?
Thanks,
Brian
Old 06-24-2005, 10:07 PM
Yeah... That be the one...
There is a pic there exploded view of all the parts...
Old 06-24-2005, 10:27 PM
RAW FUEL's Avatar
Cool, I'll give Napy another try in the morning.
Thanks,
Brian
Old 06-26-2005, 03:11 PM
CapnRam's Avatar
Got mine at ACE in the plumbing section...2.99
Quick Reply: Fuel Pressure Gauges
