fuel pressure gauge rattle
it could be a number of things the easiest would be to check if the hose going to the gauge is against the dash or any thing else any were. my gauge does this every now and then to fix it I reach under the dash move stuff around and viola problem solved for a few months. some people have installed a needle valve in the line to solve the problem.
Do you have a snubber/needle valve installed? If not this will fix your issue. I get the rattle about once a year and open the hood and close the valve all the way and then open it back up maybe an 1/8'th of a turn. Noise gone.
Cheep and easy, parts at NAPA or the like.
Good luck.
Good luck.
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I have braided line, too.
What worked for me was ditching my crappy Hewitt gauge for a much nicer $20 jeg's liquid-filled 1.5" gauge that's all mechanical.
Perfect and cheap, and no noise.
Funny you say that because my needle valve is now leaking a tiny bit and I was actually thinking about getting the snubber from DieselManor. I ended up not getting it anyway because the shipping would cost too much on such a small part.
