Fuel pressure gauge. HELP ASAP
Old 01-18-2007, 07:43 PM
TheBigNasty's Avatar
If you doubt the need for a needle valve then just try it. Infidel, of course, is dead on with his explination. As he said a 24v will buzz but the 12v will dang near blow the gauge apart.
Old 01-18-2007, 08:10 PM
Ram1999's Avatar
I did as explained in a previous post in this thread. Needle is steady with ball valve wide open.
Old 01-18-2007, 10:04 PM
inline6359's Avatar
Have you done a 12v? From the sounds of it it is a no.
Old 01-19-2007, 03:34 AM
wcbcruzer's Avatar
Is it because the frequency of the pulsations from the injection pump is a lot higher than the response time of the gauge? Thus, stressing the gauge and blowing it?
Old 01-19-2007, 10:19 AM
infidel's Avatar
On the 12 valve it's the mechanical lift pump that causes the pulsations. It's a diaphragm type pump, one stroke sucks fuel in, next stoke expels it. Envisioning this you can see how the pulsation develops. Without a dampener the needle will swing from zero to over 50 psi on each stroke of the lift pump, the faster the rpms the faster the swing. The needle valve slows the pressure change the gauge sees so what it is in fact doing is taking the average between the high and low psi.
Old 01-19-2007, 10:58 AM
zukota's Avatar
1/8 Needle Valve Napa part number:
WH (weatherhead) # 6820
dodgeguy71
17
01-19-2012 12:52 AM
carte89
11-28-2008 08:35 PM
jmccart
15
01-26-2008 09:32 PM
jmccart
01-26-2008 07:36 PM
Quick Reply: Fuel pressure gauge. HELP ASAP
