Fuel pressure gauge with FASS and Juice
What have the guys that have a FASS pump been doing to install the Edge Juice fuel pressure gauge? I know it's simple to cut the 3/8 fuel line and install a T but does anybody make a T with two 3/8 barb ends and a threaded boss for the fuel pressure sender? Thanks for any info. Eric
I built my own for my truck.....if that helps......
Originally Posted by dodgediesel
Doesn't the juice only monitor low pressure or does it have a pressure display to a certain psi???
Instead of bypassing the stock fuel filter per the instructions, after getting the okay from FASS dealer I plummed directly to the stock fuel filter inlet (then you don't use the elbow fitting they give you either). This preserves the water-in-fuel sensor and both fuel pressure test ports - then you can use one(I picked the outlet side of the filter) to hook the Edge pressure sensor to. I think it ends up being a much cleaner install. Hope this helps.
P.S. this is my first post here - hope it comes across right!
i got mine from summit its just a -6an fuel pressure adapter fitting they have them in the mags in summit and jegs but i bet just about any high perf.shops should have 1 in stock
rjm022
07-08-2006 06:30 PM
tempoffroad
03-21-2006 07:48 AM
MoparRiggan
01-05-2006 11:09 AM
Igor
09-13-2005 12:47 AM
