Fuel pressure gauge connection?
Old 04-27-2006 | 10:21 AM
Lenn's Avatar
If I connect my fuel pressure gauge line to the VP-44 inlet with a tapped Banjo-bolt. Is that where the Schrader valve is and do I eliminate the Schrader valve? I would like to avoid doing the bottom of the filter.
Old 04-27-2006 | 05:59 PM
sosborn's Avatar
Yes, you remove the schrader valve and attach there. This is how I have mine set up. A lot less work than pulling the filter, it just means you won't have the schrader if you need it. I figured it wasn't that big of a deal.
Sam
RottnRam
15
08-06-2008 08:26 PM
CZSteve
02-18-2006 06:10 PM
FORDNOMORE
11-29-2003 10:17 PM
Stamey
13
12-29-2002 05:37 PM
Quick Reply: Fuel pressure gauge connection?
