Fuel Pressure Gauge
Fuel Pressure Gauge
Just installed an Isspro Fuel Pressure gauge w/ isolator, works great but when truck is shut down the guage reads 3-4 PSI, even the day after, is this normal......
any ideas what could be causing this, at idle it reads 15-16 psi just installed a new lift pump when installing gauge, (thats how i found the bad lp) so i think it is reading correctly
Sounds a little high on both ends. My Isspro reads 0 at shut down and 14.5 at idle with new pump. Gauge calibration? You might hook up temporary gauge under hood to compare readings.
RJ
RJ
I believe you problem is likely due to the isolator - they are notorious for causing inaccurate readings.
Try temporarily bypassing the isolator to zero identify the problem.
UPDATE - went home over an early lunch, craked screw on fuel side of isolator, gauge went to 0, restarted engine filled line shut screw, 15+ psi, shut off engine gauge went to 4 psi, craked fitting on gauge side of isolator, gauge went to 0 psi tightened screw restarted enginge gauge reads 15+ psi shut it down gauge went to 0 psi, repeated for good measure same results think i got it fixed......
sorry if this posts twice i was having difficulty
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
