Fuel pressure gauge
Location: In Oroville, Ca., same house for past 46 yrs!
Diesel Manor stocks a nice gauge. Be sure to choose the one that goes high enough to show YOUR pressure. On my 3rd Gen I only need to see 20 psi, yours might be considerably higher depending on your 'school of thought' on the matter.
google DM and then check out their gauge section. Theses guys are a world of info and the directions for their 3 gauge piller pod set up was actually written in english!
get a glycerine filled 30 psi gauge from ww granger for about $20 a copper line oil pressure gauge installation kit from autozone for $11 and a taped banjo bolt from genosgarage.com for $8 and you have the best.
Administrator / Scooter Bum
Depends on how much money you want to spend, how much effort you want to go through on install, how nice you want it to look, and how accurate you want it to read. Any reason you're only after a fuel pressure gauge?
They stand behind what they sell. Most likely they will send you new gauges totally free of charge and won't even want the old ones back.
You may want to put a little pressure to them with air first, they may settle back to zero after the first use.
Hadn't looked at gauge prices in a while, what a rip off.
$250 plus for a fuel pressure gauge setup that I could put together myself for under $25.
Yes, call Grainger.
I exaggerated $25, it's more like $15 using this gauge, a needle valve and tap my own banjo bolt.
https://www.surpluscenter.com/item.a...atname=engines
katoom we run a fleet of dodges all have gauges surplus center has the glycerin gauges, we have been running them since 2000 with no failures i only mentioned ww grangers because they are everywhere. with the filled gauge you do not even need the needle valve we do as infidel does and tap our own bolt surplus center part#21-1246a $16.95 kit $11 total $28
