Fuel Pressure Gauge
Old 07-12-2008 | 10:29 AM
MikeBrei's Avatar
Fuel Pressure Gauge Help?
I have a 2001 CTD and I just ordered an Auto Meter Ultra-Lite Fuel Pressure Gauge w/Isolator and I should get it next week. The question I have is what diameter hose and what fittings will I need to hook it up to my lift pump and to the isolator? I also wasn't sure how long of a hose I would need.
I figured I would ask here before I started so I could get all the parts at one time and I could hook it up as soon as I get it.
Old 07-13-2008 | 10:24 AM
MikeBrei's Avatar
Did anyone use this setup?
Old 07-13-2008 | 12:23 PM
Dr. Evil's Avatar
Mike, try the search feature - there is DAYS of reading on fuel pressure guages.
Old 07-13-2008 | 12:50 PM
2500Ram's Avatar
I used 4' of braided SS 3/8" tubing to bring into the cab, had the isolator but it failed within 6 months so it's sitting on my shelf, I used the fuel hose Genos sells and tapped into the shrader valve on the VP with a needle valve between the Genos hose and my SS hose.
Good luck.
Old 07-13-2008 | 12:59 PM
MikeBrei's Avatar
Thanks 2500! I was searching the forums and I didn't see anything that was specific on the materials needed. I did read a lot about people having problems with the Isolator and just running a straight line. I am thinking I might just skip the isolator also and run a straight line into the cab and just save some headaches. I will just take my time and make sure everything is sealed and tight.
Old 07-13-2008 | 02:13 PM
Dr. Evil's Avatar
If you are using braided S.S. you will be fine. That is unless the bourdon tube in the guage fails, but that is not common.
A member here (Infidel) has been running fp guages on his 12V (25-35psi) using nylon tubing for 10+ years. Im at 5+ years on my nylon tubing as well.
dodgeguy71
17
01-19-2012 01:52 AM
Igor
09-13-2005 01:47 AM
Greeds22
25
09-11-2005 04:13 PM
engcogod
17
02-03-2005 09:49 PM
Patriot_RAM
10-08-2004 07:10 PM
