Fuel Pressure Gauge.
Old 12-17-2003, 10:10 PM
gandrews's Avatar
Re:Fuel Pressure Gauge.
The lack of an isolator is a concern with the ISSPRO. However the stainless braided line that Wildcat sells with their gauges is industrial strength. Install a needle valve to reduce the pulse and also provide for a shut off in case something goes wrong.
The thing I really like about the ISSPRO is they have a 270 degree sweep on their gauges. Their fuel gauge has 0 to 30 psi (which is very close to the range we see on our lift pumps) and over a 270 degree sweep makes it much easier / quicker to read.
Good luck on your choice.
George
Old 12-17-2003, 10:51 PM
DarrellB's Avatar
There's always Dipricol gauges as well I've got a 0 to 30psi in my truck. They make them in black or white face for about $70 I think.
DB
Old 12-18-2003, 04:04 PM
HOHN's Avatar
Don't worry about leaks if you use good fittings. I run braided into the cab where it connects to the 1/8NPT on the back of the gauge.
I used to have an isolator-- it was causing all kinds of bad readings (gauge would peg to 28psi and not move, or it would read negative). So i took out the isolator.
Lo and behold, the isolator had disintegrated and I was getting fuel to the gauge anyway.
Funny how once I took out the isolator, my gauge stopped acting up, and now reads fine all the time.
I should have just hooked it right up anyway. Then my VP44 would not have had to digest the antifreeze mix :'(
Justin
HOHN's Avatar
By the way-- those DiPricol gauges are BEAUTIFUL!
Old 12-18-2003, 05:49 PM
DarrellB's Avatar
[quote author=HOHN link=board=7;threadid=5596;start=15#msg226021 date=1071785077]
[/quote]
Thanks You.
Good gauges too, the fuel pressure gauge has worked great for the year and a half I've had it. The boost and pyro have been there for 4 + years of excellent service and still going strong. 8)
DB
Old 12-19-2003, 11:13 PM
Homestead's Avatar
I run Wildcat's fuel pressure guage kit in my truck. Never had a problem yet, probably never will! Install a cut off under the hood (just in case) and don't worry about.
Besides, I would much sooner clean a small diesel spill out of my interior than try and get the glycol mix out that the isolator systems use.
Run a mechanical guage and forget about it. More accurate and reliable.
Jeff
Old 12-20-2003, 12:10 PM
vtailflyer's Avatar
Hey DarrelB, I am going to be installing the post mount gauges three with the speaker as well, Looks you you did a nice job,
Any hints or tips?
Thanks
Old 12-20-2003, 07:45 PM
BADBOWTIE's Avatar
I installed the wildcat setup in my truck. I was calmed by Rod who said, they only had one leak and it was from an improper installation in "his partners truck". I would not worry about a leak if you are careful during the install.
Jason
Old 12-21-2003, 03:15 AM
DarrellB's Avatar
[quote author=vtailflyer link=board=7;threadid=5596;start=15#msg226922 date=1071943831]
Any hints or tips?
Thanks
[/quote]
Be patiant!
I've got about 4 or 5 (can't remember) coats of paint on mine. I used some stuff I got at Napa for the 2 base coats and then used the Mopar paint for the top 2. To get my EGT gauge in the middle I had to do some trimming on the pillar mount and I also left the stock pillar behind the mount to give it more support. 8)
It wasn't that bad of a job though kind of fun.
DB
Old 12-21-2003, 10:00 AM
Racer57's Avatar
Rods setup is great. Isspro Marine (black face, white letters) also a good match to the my Autometer sport comp gauges. Rod provides a needle valve shutoff in case anything were to happen but it is not likely to do so with a good gauge and SS braided line thats in his kit. Don't worry bout fuel in cab. Antifreeze in cab wouldn't be such a good thing either. Isolators seem to cause problems.
Old 07-30-2008, 09:42 AM
bowlerman's Avatar
i found an autometer than does 0-60 so im gonna use that
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: Fuel Pressure Gauge.
