Fuel Pressure
Fuel Pressure
What is the pressure that a stock Lift Pump puts out. I just installed the guage and the pump is putting out 8-9 PSI at Idle. At WOT it dropped to 1PSI. I know i'll need to replace the pump, but is the pump actually bad for a stock set-up?
I believe the stocker should be 14-15psi at idle, and it should by no means go below 5psi ever.
My suggestion is the FASSII. I'm 18-19 idle, 16-17 cruise, and around 14 WOT. Plus 4 year unlimited mileage warranty.
Yeah, my pump in stock form put out about what Moose saw-- 14-15 idle, 11-12 cruise, 5 WOT (this was with 90hp injectors, though).
Since I upgraded the lines, I know have 17idle, 14-15 cruise, 10 WOT. This is with the same stock LP.
I'm guessing my bigger injectors may need a bigger pump-- we'll see.
jlh
jlh
Originally posted by atch
Can anyone give me a good website where I can check out the prices for the fassII system?
http://www.protintnw.com/sa_dodgemenu.htm
Talk to Rip, and get the best price. I also had him make me a line to go from the filter canister to the VP with a tapped gauge port in it.
dodgeguy71
17
01-19-2012 01:52 AM
bigragu
01-24-2006 12:16 PM
mtl0727
11-05-2005 07:47 PM
darrenG
06-28-2005 08:43 AM
Flatty
01-05-2005 03:50 PM
