Fuel Pressure
Fuel Pressure
I just installed a fuel pressure gauge. At idle I have 14psi.
at WOT it drops to 11psi. Whats the lowest safe pressure I
can get away with at WOT. I'm adding a Van Aaken V5 this week.
Not too sure about the VA 5, but take (if you're still in warrenty) into consideration that dealers warrenty lift pump failures on flow, not on psi. I'd say that you're in the clear, but just remember that incase your pressure drops after the install (and you can get away w/ warrenty work after the install).
Install a pusher pump kit to run with your lift pump it will keep you at 15psi w.o.t. and take alot of the load off your stock pump. Stock pumps last a long time when teamed up with a pusher. My 01 has 100hp injectors and Drag comp cant pull under 14psi with stock lift pump and BD diesel performance lift pump kit
I used a tapped banjo bolt on the bottom of the
fuel filter housing. This is post filter pressure. I
changed my filter at the same time so I could get
a baseline reading. Idle 14 psi / WOT 11 psi. I'm
adding a Van Aaken box today. Let you know what
the WOT pressure is tomorrow. I used a mechanical
gauge with no isolator.
Dieselcamper
CAREFUL....when you say..in your signature..."then I'm done!" Barbara Boxer may be calling you a liar in 6 months!
Two years ago...all I ever wanted was 300 HP...till I got there!
Jim Fulmer, now at 804 HP, once told his tranny guy..."I'm just looking for 250 hp"
RJ
1/28/05 - No offense intended...Why did you remove your wish list?
RJ
Originally posted by 4RGSP
dieselcamper
where did you install your tubing for the gauge? I'm looking now at installing one on my truck.
dieselcamper
The only reason I say old setup, is because I replaced it all with the FASS II and -6an line.
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
