Fuel Pressue Gauge Parts List.
DTR's Cow Boss
Ok so me yes me I am goin to finally get a fuel pressure gauge setup right now I am just goin to run the gauge in the cab and put it down by the 4x4 lever then later in the winter ill bring it up on the pilliar for lights and easy view with a dual a pilliar pod. So that being said here is what I need to know for the morning see if i got the stuff i need.
I am getting a 2'' Liq Filled Gauge 30psi max no snubber or isolator cause beliv the liq filled gauge will help that out to be annouced though.
8' of 1/4'' 250psi line with 1/8'' npt schrader valve either a 90 or a 45 fitting so there will be no kinks.
A needle valve.
and a mount to mount the gauge under the dash by the 4x4 lever nothing fancy but what ever works.
Sound about right for getting the stuff i need. Iam not goin to run power to the gauge for lighting as its not really that needed
A needle valve.
03schoolbus
12-22-2008 09:22 PM
