Fuel Press Gauge, What do i need?
Getting ready to purchase a fuel pressure gauge from Genos, wondering what i need to go along with the gauge. I am going to buy the Di Pricol gauge. Do i need tapped banjo bolts, i know Genos sells them, i also see that they sell a billet cap to go on the fuel filter, would that be a better way to go rather then the banjo bolts? Thanks for the help
just install it like the pic above and close the needle vavle off then open it just enough to were the gauge works . cause if you open it to much you will get a rattling sound . and over time the pulse can kill the gauge . i been running mine with a set up alot like this for over a year now with no issues . you will want the needle valve to dampen the pulse that the vp44 puts out.
Originally posted by Roadrunner
I ran my line right to my cheap little guage and it is going coo coo sometimes could this be from air in the line too?
Did you install a needle valve in your setup? My experience with air in the line is better... It softness the pulses to the gauge and you can open the needle valve a bit more...
sal3c
13
12-05-2007 09:45 PM
j
05-16-2007 08:11 PM
