Fuel Plate Position Question
Old 10-23-2009 | 10:49 PM
Kenny Rhea's Avatar
Question Fuel Plate Position Question
I have a TST #6 plate and my truck does not accelerate as quickly after I I am thinking that I should raise the governor arm so it hits higher on the plate so when it engages it will be on a more aggresive curve. Can I adjust the afc to give more fuel until governor engages plate. The star wheel is all the way in and the Fine adjustment is set to TST specs that came with afc spring kit. The boost line on the AFC, is it moving the diaphragm to give fuel or cut off the low boost fueling? I am willing to try any suggestions. Thanks for any advice.
Old 10-23-2009 | 11:11 PM
Kenny Rhea's Avatar
I forgot to mention that before I installed the GSK I had a short puff of black smoke and now there is none. Will slding the plate forward increase the duration of low boost fueling or is it instantly shutdown when adequate boost is reached? Would it help to install the heavier spring that came with my afc kit? Thanks again.
Old 10-24-2009 | 09:00 AM
JKM's Avatar
JKM
I adjusted my plate right out of the truck, and into a box on the shelf in the shop.
Old 10-24-2009 | 01:12 PM
CarlJensen's Avatar
Here is a write up for you on the pump, plate and arm.
http://dieseldatabase.com/read.php?id=58
rocktoy
11-29-2010 12:26 PM
Cougsfan
10-23-2007 12:17 PM
bob95065
21
08-21-2007 06:16 PM
Txwelder
16
12-13-2006 08:10 PM
halerazor
05-04-2004 10:55 AM
