fuel plate install
Old 12-13-2006 | 12:10 AM
somis13's Avatar
fuel plate install
is it necessary to adjust the governor control arm when putting in a new fuel plate?
Old 12-13-2006 | 12:13 AM
Muddin_dude06's Avatar
It depends on whether of not the arm touches the plate in the correct place or not, Its better to check it than be sorry later after you put everything back together (like I am now ) http://www.piersdiesel.com/TechLeverAdj.htm
I have to adjust my arm tommorrow and from reading that link it should be pretty simple...
Old 12-13-2006 | 12:17 AM
somis13's Avatar
do you just look in through the top to see where it hits the plate then? the cut away looks easy but, is it really easy to see?
Old 12-13-2006 | 12:44 AM
Fueling around's Avatar
It depends on the fuel plate, position you install it, and if you add governor springs.
It is pretty easy to see from the top and that is the only view you'll get to make the adjustment. If have a problem with depth perception, apply something to the governor lever to leave a mark on the plate when you roll the throttle forward.
To be honest, I thought adjusting the lever was harder than installing a plate or governor springs. You have to work blind and sometimes it is a bugger to get the cover screws loose.
Old 12-13-2006 | 01:29 AM
I would think so as long as you can get the AFC housing zip-tied out of the way, I will be doing mine somewhere around 3:30 tommorrow afternoon once I get done with my final . I will post back my experience with it and try to give you a better idea with what your in for...
Old 12-13-2006 | 10:05 AM
DL1221's Avatar
Originally Posted by Fueling around
It depends on the fuel plate, position you install it, and if you add governor springs. . .
When I installed my No 8 plate, I left it in the stock position and I didn't adjust the lever at all, the truck seems to run fine. I can't see exactly where the lever is, but it seems to hit a bit above the bottom tip of the plate. The instructions say it should hit at the bottom tip. Should I move it down, or leave it? My instincts are to just leave it, since the truck runs OK. I've also read that if you don't move the position of the plate, you don't need to adjust the lever, correct?
Old 12-13-2006 | 07:41 PM
somis13's Avatar
the plate I have is a # 10. does the accelerator pedal need to be pushed to the floor when I make the adjustment to the governor? or does that matter?
Old 12-13-2006 | 07:49 PM
infidel's Avatar
I've found if you put the plate in the stock position no adjustment is needed.
If you notice in the instructions that come with plates there is no mention of adjusting the gov arm but they do specify to install them in the stock position.
Old 12-13-2006 | 10:54 PM
#10 in an auto? Did you install governor springs, too?
You just need to lift the fuel shut off lever and roll the throttle forward until the lever hits the plate.
Old 12-13-2006 | 10:58 PM
I wouldn't move your lever, especially not down. If you decide to nudge the plate forward, the lever should be good as is.
plow
07-20-2005 09:40 PM
Rockcrawler
14
06-23-2005 12:40 PM
big green
05-13-2005 07:21 PM
crossy
03-28-2005 06:12 PM
David Gardner
06-26-2003 10:37 PM
