Fuel Plate
Fuel Plate
If I bump Up my Fuel Plate On my cummins will i get some more power fuel and smoke if so how do i do that allready turned up the star wheel a lil thanxxx get back to me
you have gauges, you might as well grind ur stock plate to a #10 or #100, u'll be very happy. Do a search for "free 12v mods" "fuel plate" or "grind Fuel plate" and there should be hours of reading on how to do it. And after you grind it, u can move it forward however far u like it. you can move the stock plate forward, but to get more fueling u should grind it. And also moved ur AFC forward if u want alittle more preboost power and smoke. Search for "slide AFC" and u'll find lots on it. And once u get the free mods done, theres LOTS more to do if u got alittle money.
yes.... sort of. the stock fuel plate can be slid forward(towards front of motor) for more power, but only a small amount more of power can be had with the stock plate, cheapest thing to do is grind your own plate, by taking the stock one and grinding it down so the arm that makes contact with it will travel further. there is a post on here of fuel plate profiles that you can look at, im not sure where its at though, just use the search and you'll find it.
jason
jason
I think I can... I think...
Also when you increase fuel you need to increase airflow and it's a good idea to know what your exhaust temp is doing. Extra fuel means extra heat.
Thanx Guys yeah i run about 29 psi of boost my egt's a resonalby low usually areound 6 - 700 degrees maybe 900 when im on a hard grade with a 16'ft trailer and a mustang im tryin to keep the powr down a little till after the summer wanna do the small stuff i dont wanna smoke the stock trans yet after summer bring it all trans will be built thanx for the help next step is the KDP any ideas are welcome loocking for some good setups on trans stuff and mods get back thanx for the help
If ur trans is in good shape now, a upgraded Torque Converter and Valve body say from Goerand, DTT, or another quality brand would do wonders for u. You'll think it's a whole different truck, and it should be good for some decent hp/tq.
Yeah trans shifts great lock up is great shifts hard ill def check that all out BOX5 how hard was your 5 spd swap and how much did it run you
West Coast
07-01-2007 02:32 PM
Rockcrawler
14
06-23-2005 11:40 AM
banks twinram
02-05-2005 10:38 AM
