Fuel line question
Originally Posted by atch
Was this a stupid question?
Just no one with the answer has checked in yet.
I don't believe anything is changed inside the tank, all fuel line upgrades are between the tank and the pump.
phox
Originally Posted by phox_mulder
I don't believe anything is changed inside the tank, all fuel line upgrades are between the tank and the pump.phox
RJ
Originally Posted by SmokinFive9 4x4
....how much hp will the stock size (3/8"?) support before it hinders performance?
FASS comes with 3/8" and will handle...along with the different fittings....all you can throw at it.
If I remember correctly, my stock system started pulling below 5 psi FP at 340 hp. Went to Scotty's Max Flow System and it solved all problems up to 450 hp. His new design will go even higher, I believe, and also does a great job of protecting the life of lift pumps...I never had to replace mine for 60,000 miles, at which time I went to a FASS.
RJ
When they run the larger fuel lines from the tank to the lift pump, do they also replace the fuel pick-up line in the tank?
I had trouble finding a good answer to this as well. I belive you are wondering how to hook the new lines into the system. A 3/8 line will slide on the nipple that comes out of the tank after you pop the plastic clip off of it. Put a hose clamp on it and it won't move.
And no it is not a stupid question.
Randy
According to flow charts 3/8" id tubing will flow 22 gph with a .5 psi loss per ten feet. At 22 gph if you were getting 10 miles per gallon the 3/8" line could support a speed of 220 mph.
ctd4stan
05-18-2009 02:56 PM
txasylum
03-22-2008 02:47 PM
Tiara3100
01-14-2008 10:06 AM
Begle1
19
08-25-2006 11:31 PM
