Fuel injectors 99 dodge 2500 diesel
Hello
new to this form But,
I was wondering if you could help me threw the maze of fuel injectors.
What type of injectors u guys like ?
I don't want to spend a hole lot. I'm only looking for better mpg. an fixing my bad injector!
Here's a couple I've been looking at...
http://www.dieseldynamics.com/dodgekits.htm
http://www.jegs.com/webapp/wcs/store...64306_-1_10299
Also
would I need to order any special tools an is it hard to get to the 5th an 6th injectors ?
Thanks for ur help
Denny
I'll check back tomorrow...Thanks again.
oh
99 dodge 2500 diesel ...stock. daily driver with 8 ft. truck camper
Also
Thanks for ur help
Denny
oh
here is where I got my injectors http://www.mwfi.com/dieselPage/dodge%20injectors.htm
I have not noticed any better fuel milage , but I feel I get into it more you can't do that. I would also like to add that the only special tool I used to change mine was one othe the bolts removed screwed in to the top of the injector. and a wonder bar, "the flat crow bar" other that that an inch pound toqcrc wrench. mide west fuel injection sell the kit for $300. you may need a pair of long skin plyers to get the copper washers out if they don't come out with the injectors. there are alot of write up on this topic for ya. one I made up was, my the diesel gods be with me, injector change for the change they were not needed but as some one said they were sure needed to get the prime back in the motor. search and read that up to , for that you will also may need a battery charger to keep the batterys up. hope the info helps. cole
Before you even get injectors you need to get a set of gauges, a 3 gauge pod with boost, egt, and fuel pressure would be a good start. Another solution to gauges and injectors is a Edge Juice w/ Attitude for $600. I bought a used set of RV275's which had about 40 horse rougly to give me truck a little more kick with the Juice.
I bought my injectors from a member here used. At first I thought I wasted my money, but the next weekend I pulled the trailer and I was very satisfied with the results. With my Rv275's I now can get 12mpg pulling and I wasn't able to before.
12 mpg...dang son. guess I can't complain. with the camper 14 to 16 mpg. That's without saying I drive like an old man ! Normally 18 mpg ( sometimes 20). I start off at 2 thousand rpms and end up doing 70 mph at 2000. rpm.
I order a fuel pressure gauge/pod last wk. when I replaced the fuel pump ( 186 thousand mile). Luckily I didn't screw up my Injector pump (1700. dollars)!!! when I "finger" out what injector. I'll order a temp. gauge with it.
alright
let me go checkout ur links. Keep the info coming. I need to get on this, I have a road trip on the 17th.
Thanks for ur time guys
alright
Donmacky
02-01-2014 06:07 PM
joebishop23
10-29-2007 10:19 AM
