Fuel gauge
Fuel gauge
My 96 Ram 2500 has a fuel guage that stays on full at all times. It started going bad by not showing correct fuel level. It would jump around now stays on full at all times. Is there a quick check to maybe run down the problim with out dropping the tank and checking the float.
Can use any help. Thanks.
Dodge fuel level sender assemblies are known to not last long.
Someone found a fix for the problem, rather than shell out $$ for the assembly,
but still requires removing it from the tank to perform the fix.
Either dropping the tank, or lifting the bed and going in from the top.
A search for "fuel level sender" might find this procedure.
phox
nrussell
07-23-2008 08:58 PM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
