fuel box to incab swap
I have an 02 3500 6spd.I curently have a vanaken 100 horse fuel box and now wont some more power and some incab adjustment.I allready have a 3 gauge set.Boost,egt,and fuel pres.The norm. Im trying to decide on the edge J A setup or the comp box.I heard some rumors that the comp box is not a good setup for towing.Thats what I do the most of.I do some light sled pulling and slugin it out at the local drag strip for a little fun.I really dont wont to pull my gauge set but Ill do what I gotta do for the best swap.
Im all ears and open to all info.Thanks
Basically, they are the same thing.
I do not know if the programming parameters have changed, but at one time, they were exactly the same for power, economy, smoke, ect.
The exception is the defuel capabilities of the Juice depending on certain driving conditions.
Remember, these are made by the same company Edge.
Dave
Dave
Yes, I thought the Juice was a comp with digital gauges. I dont have a comp (yet) but im pretty sure you can tow with it but you would probably want to leave it on stage one or two. anything higher than that ane your EGT would prob. be though the roof.
I had a problem when I bought my J/A and I called the 1 800 number, I explained that I could not adjust the power levels, they sent me a box right away, come to find out there was nothing wrong with it (I think) as when the J/A is first turned on its on level zero, I went in the sub menus adjusting things in the same order as described in the owners manual.....but the power levels have to be changed BEFORE you can adjust the "low boost setting" all I had to have done was use the up/down buttons to get it off the stock setting and everything would have worked just fine.
the ADR seems like its loaded with extras and makes more power, I cant speak for it but I read threads on it quite a bit,
As for gauges you can leave the stock gauges you have, as there is a simple dash mount for the monitor, this is what I did orginally, then I removed the gauges, and went with the pillar mount for the monitor, as it looks so much cleaner. You could get just the comp and use your gauges, but there is so much more you can do with the J/A, and its worth every dollar.
oh and last week the hot unlock was on sale for 50$ I did not need it but I bought it anyway.
Thats great.Thanks for the info.Dose anybody have the A2 monitor with the back up cams?I think that would be neat with the cam on my headake rack for hookin up my gooseneck.
Treangen
63
07-07-2008 07:42 PM
RH Welding
03-02-2008 10:42 AM
04ctd
10-05-2006 08:27 PM
Dusty Ratcliff
09-19-2006 07:35 PM
flinn101
14
12-14-2005 09:43 PM
