FRRP, is it enough?
Mine will support RV275 Injectors and edge comp with no issues. I have it set at 20PSI at idle and it won't drop below 130PSI at WOT. The pump will snap the fuel pressure gauge back to 20PSI within a second of letting off the throttle. I also do have a big line kit from the filter bowl to the VP, not sure how big of a difference it makes but it does help.
Well I guess I'm going to find out if it will work. I just ordered the frrp, edge comp drag box, a bd stealth cover, and a bd j-hook the other day. Pump and stealth cover came in today and the comp and j-hook should be here in about a week.
