Front Door Speakers, What Fits?
#46
Originally Posted by SuperDave4x4
Yeah please let us know how they sound and fit as I'm looking for a set right know. I need to go and find out what model those Alpine 6.5" speakers are, but I think you may have found a better deal.
Also what do yall prefer 6.5" or 6x9" in the front door? I'm not too savey when it comes to speakers?
I'm listening to Pro Audio (Highend Clarion) 6.5" 200 W components in front and the 150 W 5 1/4" Pro Audio's in the rear, Dual 10" Pro Audio subs under bench Planet Audio 5-Channel amp and it sounds great! Loud, clear and crisp! U can hear it for blocks if I want U to! I don't have that massive Vibrate from the subs (10's vs. 12's) but it sounds great anyways! Cheapies (speakers or amps) seem to blow quicker and the sound goes flat quicker, I also think, IMHO, that individual speakers sound better then the stacked two-ways, three-ways or four-way speakers and a good highend amp is just plain cleaner! Just my $.02
Cory
#47
Okay, issues already. I didn't expect to see 10 wires in the factory harness hooked to the infinity speaker. That's right TEN! Now what? I am assuming I am Just rewiring the fronts all together now?
Crutchfield sent me a little two wire harness with what I was going to use as my fronts (6.5's), it's useless against the factory one. Maybe they sent me the hookup for the non-infinity system?
Anyhow, I'm going to pop the passenger side off, I guess it's going to look the same.
Speaker depth is sweet, I probably could've gone with a 3 1/8" 3 1/4" depth, I know for a fact that 3 1/16" is going in no problem.
Anyone know which 4 wires are the + & - and the tweeter feeds??????
#48
Oaky, I'm gathering that the harness powers ALL of the one side speakers (rear, tweet and the front it connects to) so now what?
I'm really not into rewire the WHOLE truck.
Help.
Help.
#49
Yeah, having the factory Infinity system is actually quite a bit of a hindrance when you go to upgrade it. It's not made to be upgraded. I recommend that you run your own wires. IT ISN'T HARD. Trust me. All you do it buy some 12 gauge twin lead speaker cable and run it from the speaker hole in the door through the door boot (on both sides of the door boot, remove the oval-shaped plastic bulkhead and just tuck the boot into the hole--it'll stay and keep water out), up under the dash, and across the back of the dash to the head unit area. It's really a piece of cake and much easier (and better) than using the puny (and complicated) factory speaker wires.
#50
Okay, negatory on the depth thing, the maganet is touching the window frame track (both sides) So, I am into building them out a bit, not much, about 1/4" should be fine. Clearance to the door panel is not an issue as stated by others, plenty of room there.
Tha only issue I have with running new wires is that I would need to wire ALL six speakers if I decide to re-wire the fronts.
Laugh if you will, but I am going to detach the infinity amp and crossover from the factory speaker and mount in inside the door. This way I still have a Low freq. crossover for the tweets and don't have to rewire the other 4 speakers. As I stated when I started this project, the truck is not ever going to be for crusing the beach picking up honeys with my "boomin" system. This is just an attempt at improving the overall sound of the system to inhance my Sirius experience.
BTW, I ended up getting a two speaker kit with off brand dynamat from "The Evil Empire" last night, $9.99 for two 10" pieces, it sould serve the purpose.
I'll check back in with pics of old v.s new and how I built them up to clear the window and associated hardware.
#51
Here goes.
This is how close to factory depth my new speaker were (factory on right)
I realized I could disassemble the actual speaker from the plastic container is was in and then un-bolt (two torx screws) the amp/crossover from the back of the speaker. I then used heavy duty two sided tape to mount it back inside the speaker "holder".
If you notice, I had to cut off the "tabs" and alignment pins from the top of the infinity speaker holder, this was done with a cut off wheel in about 30 seconds.
The sound is greatly improved over stock, much more mid and high. This will be great for when I get the sub hooked up.
#54
Originally Posted by jfpointer
They have amps on them.
#55
Originally Posted by AggiePhil
Still doesn't explain why they need that many wires. Do you know what the wires do specifically? That's what I was wondering.
I am VERY happy with the results, anyone that needs anymore sound is just trying to have others hear it. The clarity is 100% better over stock, I have much better mid and high tones.
Heres the way I see it.
Each speaker has power, ground, remote (turn on), the + & - for the tweeter and rear speaker on that side and the wires for the 6X9.
I thought there were 10 wires on the amp/crossover.
I can only account for 9 now, so I guess either I counted wrong when I had it apart or the other one is just in there for the heck of it.
Everything runs from the headunit TO the amp/crossover, and then out to each speaker.
#56
1 Post
Looks like PJ explained it, but the amp/crossovers on the fronts run all the speakers on a given side.
#57
Originally Posted by P.J
...The sound is greatly improved over stock, much more mid and high. This will be great for when I get the sub hooked up.
My Infinity system 4 door speakers work, but not much sound out of the rear doors. My A-pillar tweets don't work. Is this because the front door amps are bad?
Second, is your "greatly improved" sound just with replaced speakers, using the stock door amps, and the original head unit? (just to clarify)
Third, I don't know speakers. With your new 4-way Kenwoods how does each part get the right signal? Does the door amp do it or does the speaker have crossovers built in?
Fourth, what would be the result if I replaced all six speakers and wired directly to the original head unit, deleting the door amps?
#58
Here's my question. Is the wiring harness behing the head unit the same whether your truck has the Infinity system or the regular system? I'm going to install my Alpine head unit in my new truck and it's currently wired up to connect directly to the harness in my last truck (no Infinity system). Will it plug straight in to this one too? Thanks.
#59
Just some background, my infinity head unit took a dump, the back channels had no sound (not the amp, the headunit) otherwise I would have just bought a stand alone Sirius unit with FM modulator and been on my way. But, like all things, this turned into an all day, $400.00 job, but well worth it.
#60
