front bearings/hubs
front bearings/hubs
The bearing in the front end are howling and looking at the price of the hub/bearing $209 it gonna be that way for a while. Does anyone know if those hubs can be pulled apart and greased? Also can a earlier model knuckle/hub/rotor be put on with the old style replaceable bearings and locking hubs?
If you can get those bearings for that price i would go ahead and stock up!!! I paid over three hundred for mine. To the best of my knowlege no they cannot be changed out with anything other than the oem replacement neoprene bearing.
DTR's Toad Wrangler
If I where you I would seriously look at this. I wish I had known about this before I changed mine.
http://www.emsoffroad.com/
I was going to go with the EMS kit on mine last Dec. when my D/S bearing went out. I talked with the owner and they didn't have the kit available yet. They were waiting for the spindles to be shipped. It would've been another month or so to wait. I needed D/S bearing, frt pads and rotors. That would have been a nice payment on the manual hub conversion. Oh the kit for my truck was going to be around $12-1400. Some people don't think it is worth it, others try to argue about fuel mileage savings. To me it would have been well worth it.
I wouldn't let it go too long. The longer you wait the more $$$ it'll cost. Also the possibility of it coming completely apart or locking up on you on the interstate If you are able to do it yourself, 200 sounds pretty good. I think that's the lowest I've heard so far.
Another option is to retro-fit a Dana 60 Hi-pinion axle from a 90's (????) Ford F-350. LanceD did this and has had great luck with it and he pushes his hard with some very difficult offroading. You can find Dana 60's like I mentioned around $1200 IIRC.
I was driving my '99 dually on interstate at 75mph towing a light boat, my front left wheel hub came apart, snapped the shaft hub bolt off, and wheel came loose, truck went on both lanes several times with boat swinging like a gunny sack. Wheel held there by brake caliper, and I dragged to a stop in the middle of the median.
Stinky pants factor very high. I had to be towed and buy dealer full price to replace the bad hub. 1 month later the other side went out, this time I was at a stop sign, turn right and wheel fell off right there.
Change the bearings, trust me, they don't just go bad, they SEPARATE, and if you look at the big nut in the middle think it will hold.....it won't, it will strip threads off or snap shaft, there's too much force in there
No, you cannot service them, they are made that way so people doesn't mess with it. Let us know where you found them at $ 209.00 please.
rockauto.com has them for $162 for the 4 bolt and $192 for the 3 bolt.Suppossedly you can get another 5% if you put turbodiesel in the how did you hear about us spot. I haven't ordered from them yet but haven't heard anything but good things so far.
The $209 was from both NAPA and Autozone. I have ordered from Rock Auto, good service, good parts but you need to calc out the part + shipping. 90% of the time I found that it costs the same as buying locally and paying the tax. Planning on doing them this weekend just gotta get to work 2 more days....
I'll agree that some things are very expensive shipping wise. I priced a set of rotors and the shipping was all but $50.I just priced a set of unit bearing hubs from rockauto and they totaled only $323.78 + $16.52 shipping.Then 5% off is $16.19 which all but pays for the shippng.
New bearing, new rotors, new carbon/metallic pads, new Pro Comp 9000 shocks, new stabilizer, new track bar. Finally done. Unbolted the caliper, unscrewed the nut on the axle shaft and the rotor and 1/2 the hub landed on my feet. Bearings were either square of hex shaped, who says you can't take those hubs apart?
91oldranchtruck
01-31-2011 09:45 AM
jokers
10-15-2010 07:48 PM
