Friends '99 Lost power.
High all.A friend of mine has a '99.It's bone stock,& a few days ago he passed someone,& lost power for a few minutes.Then it came back,& so far seems to be runing normal.New fuel,& air filters just done.Still on the stock lift pump.Could that be it?Any info would be appreciated.Thanks.
The two places I would start are get it scaned for codes to see if it has any set and have a FP gauge put on the LP and check its condition. The dead peddle syndrome is ussually not a good thing.
Sounds like the APPS (accelerator position sensor) MIne would do the same thing. He should have engine light on when it happened.
This is were I got mine. Hoeslidiesel
Hopefully its not the IP going out. Might be the APPS. If you need one give Eric at www.hoeslidiesel.com a call. He'll hook ya up.
RAF, I've got pretty much an identical truck to yours, except for mine is a 2500. How do you like the boost fooler and elbow? Does it help much?
dieselcrazy
05-08-2003 11:07 PM
jet
11-15-2002 12:43 PM
