FP guage in, now for some questions!
to start off, again, what is the "perfect" psi i should be looking at?
now, i got the steering column pod, and i don't recommend this to anyone, man did i have such a horrible time trying to get that thing to fit, but anywho, after i got it on i noticed that my gear selector indacator ( you know the little red thing that indicates whether your in P R N D 1 2) ok, that is not lined up right anymore, when i put it in R it goes between P and R and when it's in D it's between N and D. so what or why did this happen? or did mayby it been this way for awhile and i just now noticed?
well that's all for now, thanks.............
ok, here are my FP #s but please give me a bright side to look at.
i get 11 psi at idle, about 7 at cruising, and i can suck it down to 0 at WOT!
and i'm sure everything is good, with the connections and all i mean, i ran fuel in the cab b/c i havent heard good things at all about the whole isolator thing, but what i'm really trying to say is, how far should the needle valve be open, i just opened it until i got a reading, could this throw something off if it ain't open enough?
I don't think it will throw anything off, I run mine barely cracked open. It just makes the gauge reaction slower (like when you start the truck). As for your fuel pressure, I would run and go get a Holley Blue and plumb it up and forget about it. Maybe not the best setup, but it has worked great for me. Good Luck!
Originally Posted by Ridiculous
caleb, please enlighten me on this holley blue that you speak of!
i got the Bully dog fuel system from Jegs for cheap. it is great and i also have 23 idle and 15 wot, not running the regulator don't need it.
Try shifting the lever all the way down to 1st and sometimes this helps the indicator find it's correct spot.
see ya scotte
see ya scotte
You can get a Holley for about 120 bucks.
Nothing much you need. Just cut the S.S. line and get some rubber fuel line and a fitting for the "in" and the "out" side of the pump to attach to the fuel line and thats it. And a few hose clamps. You can wire it however you want, but I ran a relay from the stock lift pump harness so it will fire when the factory pump does. Its a pretty easy install. I would recomend running the regulator, no need in pushing to much fuel, I hear it can be hard on the VP. I have been meaning to turn mine down for a while but I havent got around to it! But it's probably no big deal. So, thats it, pretty easy to do.
OH...BTW, the pump mounts to the frame.
