FP guage
tryed my best to get a snubber shot for those that don't know what it is.......hard to see, but its a .020" hole. I measured it. that is the only entrance for fluid in to the guage....
![](http://i144.photobucket.com/albums/r193/demon_044/Snubber.jpg)
not to hijack but, what about these?
http://www.dakotadigital.com/index.c...rod/prd350.htm
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=350/category_id=244/home_id=59/mode=prod/prd350.htm[/URL]
I don't have any problems with fluctuations at all in my 24-valve. I don't even run a needle valve, I just tap directly into the Shrader valve on the VP44, then to a rubber fuel line, then I use 1/8 copper tubing directly to the gauge in the cab. Absolutely no fluctuations, steady as a rock.
However, on my 12-valve its a different story, I need the needle valve to just be barely open to keep the gauge steady.
I dunno bud, I've used hundreds of guages from various manufacturers thats a pretty standard hole. you are looking at the hole inside the circle right?
I can't believe 25 ten thousands for a guage hole being very useful, getting plugged far too easily. 2.5 thou..... I've never seen one that small.
I upgraded to the Vulcan Big Line Kit .......................
But the new kits are changed they have a fitting in the elbow to allow hooking your gauge directly to the VP44 or fuel filter...
But I would suggest stay by the filter there is less pulses. The filter housing dampens some of the pulses that the VP44 creates...
DTR's Cow Boss
![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
http://www.bellautomotive.com/asp/pr...s.asp?id=24618
bigragu
01-24-2006 11:16 AM
ram4fun
13
03-14-2003 11:14 PM
Dodgezilla
03-12-2003 01:50 PM
