FP gauge install
FP gauge install
Got my Isspro fuel pressure gauge and ran around town to get valve, tubing and associated connectors. Plan to come off bottom of fuel filter with banjo bolt, valve and then tubing to gauge. Do I need to bleed the nylon tubing to the gauge (and how?) or will a little air in the line be a problem? Am I overlooking anything? Any tips or tricks? Thanks.
No need to bleed the line... The air has no bearing on the pressure reading.
You need to install a needle valve in the system and bearly crack it open like maybe a 1/4 turn if that...
Check out my web page for some tricks...
http://www.frontiernet.net/~mopar197...icol_gages.htm
Took me 3 trys to get fuel pressure gage working
without ' diesel' noise in cab.
1st: Adapter at pressure sense port with 1/8 copper line to
the small 30 psi gage ( autometer )
" TOO much noise in cab.
2nd Change line to Flex braided hose, still to much noise.
3rd Got a Bigger banjo fitting from 'Geno's, with a taped
hole for a bayonet fitting, Rubber fuel injection hose
from fitting to firewall, ( installed a cut off bolt
shoulder with a small hole drilled in it ,inside the hose for a snubber )
Changed to the 1/8 copper line at the firewall,
mounted the gage with a hose clamp( the kind with
the rubber cover) under the top right corner of the
dash glare shield, AND, NO NOISE>
spooled142
03-19-2009 09:10 AM
ado2b1
07-06-2007 10:27 PM
AndyMan
05-11-2007 07:50 AM
QWKRTNU
09-26-2006 10:22 PM
