formula for speed
formula for speed
hi i just bought a 98 quad cab sb 12 valve auto. i was wondering what i can do to make it really fast but yet streetable. my best friend has a 300z non turbo him and i have always had our own hp wars so i was wondering how i can make my truck faster than his car.
Gonna have to start by dumping a couple grand into the tranny. Get a good torque converter and a valve body. After that, you're looking at close to $300 for guages and a pod. Then throw a few more hundred at a 4 inch exhaust system. About $60 for a BHAF. $100 for Governor springs. Get your timing advanced a bit more. Like 16 degrees. Either buy the tools to do it or pay a pump shop. I got mine done for less than the price of the tools.
After that, the power is cheap. You can pretty much double your power for nothing. Fuel plate that you can make yourself, and AFC tuning that will blow your mind. With pump mods that you can do for free, you can get enough fuel to put your turbo at the end of its efficiency.
If you can swing the grand plus for a better turbo, go ahead and get new injectors and delivery valves. At that point, I wouldn't hesitate to line up next to just about any 300ZX. Turbo or not.
Don't forget to tab your KDP before you do anything.
Fuel & air is your best friend when it comes to that
humm i wounder if my truck will woop up on a z. my friends mom has one and she wants to race me. injectors help out quite a bit get some 370 marine, to go along with ur pump mods.
a non turbo z is junk .. a 300lb dude on a huffy can out run them so its not saying much.. Get some gauges and an exhaust 1st, trans 2nd, free mods 3rd, 4th intake horn and cold air intake, 5th 3 or 4 gsk (the 4gsk will need valve springs) then start looking at injectors, turbos, exhaust manifolds and etc. probably by the time you get the free mods and the gsk done ull already be driving around that 300z
snowmanx
09-26-2006 08:12 PM
schorb
16
08-09-2004 12:09 PM
