fog lights?
fog lights?
i want to install OEM fogs on my truck in the bumber like stock (did not have originally). 1}Can an OEM pair from say LMC still mount in the bumber like stock? and 2} can the headlight switched be changed to control them or do i have to install a seperate toggle? Thanks in advance
Wire them up like this using the marker light power wire to activate the relay instead of a switch:
http://www.classictruckshop.com/club...h/foglites.htm
The plastic inserts in the bumper have a larger hole for the foglight option. When I ordered my OEM foglights the kit came with new inserts. The hole in the stock inserts may be able to be enlarged to fit.
...using the marker light power wire to activate the relay instead of a switch:
Another solution would be to connect to both headlight lines using diodes on each to isolate. That way they will turn on with your headlights but you wont cross connect the H/L beams.
Right, When would you "JUST" marker lights? You could always wire it up to the headlight power wire for activation and use the HD relay harness from LMC truck for the headlights.
I have quite often. When checking into an RV park in the evening I leave my markers on while in the office. How about leaving a drive-in before the end of a movie (yes we still have a drive-in in town). Point was, you never know when you'll need just the markers but why remove the option for an "easy" fog light hook-up?
ya i use just the markers quite a bit, if parked on side of interstate we turn off headlights, etc. dont worry we still have a drive in too haha. but ill get under there tonight to see what i can find out.
bullboy85
12-18-2009 12:55 PM
fjbiker86
37
12-09-2007 07:29 AM
patriot dodge
11-23-2007 07:57 PM
Mcmopar
71
02-27-2007 01:58 PM
msatow
09-27-2006 07:32 PM
