Fog Light Replacement
Has anyone had any luck replacing the fog/driving lights with aftermarket lamps such as the PIAA 530"s? Looking for an option that fits in the existing light openings.
i know many have put piaa's in there. not sure of the model number though. i was going to put piaa's in there at one point, but then discovered they were quite overpriced.
i went with bosch compact 100's instead. good light output, far cheaper.
as for just bolting in, most aftermarket lights won't. i got lucky and found a piaa bracket set on clearance from an online vendor. it was there last one, and i don't think piaa makes it anymore. it was a kit to fit the rounds in the stock location. basically just large 90* brackets with holes to mount to the bumper supports on one side and the light stud on the other. all holes are oval to slide for adjustments.
maybe you could fab a bracket if you have the ability to do so? or do some googling for some other company that makes them?
I have the piaa ion yelow for my fogs I think they are 530's installed them 2 years ago and I would never go with anything else I love them and they take a beeting. They only thing that drives me nuts is I normally have to clean the salt off them when I get off the highway in the winter otherwise they are usleless on the back roads where I want them. But I'm guessng that's going to be the case with any light in that location?
Sent from my SPH-D700 using Tapatalk
M1AM14SPUR
05-27-2011 10:24 PM
480Ruger
10-23-2008 11:28 PM
fjbiker86
37
12-09-2007 07:29 AM
twvette
12-30-2006 10:49 PM
