Flywheel hydraulic pump
I saw on another forum that some of the cummins engines (5.9s) in larger trucks have a flywheel driven hydraulic pump mounted where our starters are and the starter mounts on the opposite side of the engine. I want to do this in mine, or maybe put a pump on the passenger side and leave the starter alone. would I have to get a different bellhousing? is there a pump that mounts in the hole where you put the tool for turning the engine? help me out! thanks!
95 2500 cummins, FORD HIGH PINION DANA 60 FRONT AXLE, 100 plate moved forward, 3800 governor washer mod, K&N cone, strait pipe, Auto meter gauges, TC lockup switch, 3 inch PA body lift, 6 inch DC lift, Irok Radial 39.5/13.5/16.5 on Stazworks beadlocks, Atlas springs, TrailReady bumper KDP killed. thanks Dave!
Hey infidel, I think he's got a 4WD.
The first problem i see , IF you find the right bellhousing-engine adapter , is that you would have to lose the tranny heat exchanger , which probably wouldn't be too big of an issue in Guam , i gather it doesn't get very cold there.
Jona Gold
27
01-03-2024 08:54 AM
jesussaves
06-28-2012 02:36 PM
