Fluidampr I need help ASAP
Old 03-02-2007 | 06:16 PM
BigBully's Avatar
I finally got my engine in and went to put the fan on and its hitting the dang Dampner, Anyone know what the deal is? I didnt see any thing the fluidampr site that said anything about any clearance problems.
Old 03-02-2007 | 08:44 PM
wildmanben's Avatar
Is your fan clutch tight? The belt lines up with the damper right? Mine doesnt hit. odd.
Old 03-02-2007 | 09:13 PM
BC847's Avatar
1st Generation Admin
I had the exact same problem. As installed, the Fluidampr just clears the fan with maybe an eighth of an inch clearance. When running, the fan just kisses the face of the damper.
I ended up making what amounts to a 1/8" thick washer that goes between the big nut and the hub of the fan assembly. With that, there's now roughly 1/4" clearance. Running, it clears the fan OK.
Still though, I'd like more space but it works.
Old 03-02-2007 | 11:38 PM
BigBully's Avatar
The clutch was new 5000 miles ago, the fan hits before the clutch nut even gets tight, I had to put 4 flat washers in the clutch to even get 1/8 inch clearance on the fan to dampner.
Old 03-02-2007 | 11:45 PM
BigBlue's Avatar
Silly question but is the dampner pushed back as far as it can go?
Old 03-02-2007 | 11:53 PM
BC847's Avatar
It doesn't push back like on a chevy small-block. Just bolts up.
Old 03-02-2007 | 11:59 PM
BigBully's Avatar
Yes and the belt lines perfect
Old 03-03-2007 | 07:24 PM
BigBlue's Avatar
Whoops. I knew that.
Old 03-03-2007 | 07:43 PM
John Faughn's Avatar
the damper made of 3 pieces , the outside-metal , the rubber middle part , and the inside-metal , some times the outside part slips off the rubber .
Can you see if the seal is riding on the same old spot on the damper ?
Old 03-03-2007 | 07:47 PM
fightin physics's Avatar
no rubber ring on the fluidamper... its a viscous damper
Old 03-03-2007 | 07:48 PM
BC847's Avatar
The Fluidampr is of totally different construction. http://www.fluidampr.com/HOWITWORKS.htm
Old 03-03-2007 | 08:41 PM
fourspeedracer's Avatar
I dont know much about hotroding diesel's. But be very careful useing a fluidamper , know from experience. Dont care what they say and they do go bad. thats on a racing small block chevy at hi rpm's.(8700)
Old 03-03-2007 | 09:37 PM
BC847's Avatar
Actually, Cummins has used a viscous type damper in a number of applications. In the industrial setting, Cummins recommends a through inspection every 2000 hours or two years.
They (Cummins), are very specific that the fluid will become hard with time.
Ref: Operation and Maintenance Manual
Industrial B3.9, B4.5, and B5.9 Series Engines
Bulletin 4021389 printed Aug 2005
The Fluidampr however ~ "The fluid inside the Fluidampr will NEVER deteriorate in a high performance race or street application. The fluid is good for life, and Fluidampr stands behind this claim with a 100% money back guarantee".
Ref: http://www.fluidampr.com/ASKTECH/20.html
CZSteve
10-05-2008 09:14 PM
PRO-NRA
01-26-2008 12:28 AM
93dodge
10-17-2007 03:07 AM
DalmationDodge
13
11-13-2006 05:12 PM
D.Wiggs
16
10-15-2006 10:10 AM
