flosser 9104's
out of stock
Parts quick is out of stock on these bulbs but I did find them through Maryland metrics.com for 4.65 a bulb, The catch is a 50.00 minimum order. If you can get a couple of people to go in with you this would be great.... or you could just never have to worry about buying headlights again.. I got mine in and installed and all I can say is WOW! These are bright
got my truck back from the shop, Flossers are definitly brighter, but hi-beams will stay on for about 10 minutes or so, them go out and flash on and off, until I switch to low beams, low beams work fine no issues, but the hi-beams flash on and off religously after 10 minutes or so.....
think I need a upgraded harness?
well, they were on the first time for a while, then it seemed like every 10 minutes or so, I never really timed it to the exact minute, but.......????
I gotta have hi beams around here!, Although the low beams are waaay better then the stock hi beams......
sounds like your headlight switch is getting weak, and the higher wattage bulbs are causing it to have a mental breakdown.
You really want to add in the relay kit, before you let the smoke out of your headlight switch. Or, just get a new switch, and hope for the best.
Good Luck
Good Luck
dieselman2300
01-24-2008 04:26 PM
dieselman2300
12-02-2007 02:54 PM
