First ride with my new Mach 5's
#31
This could also be a testament to how well the Adrenaline wrings every last drop of fuel out of the VP44 regardless of 100 or 250 hp competition injector.
Tonight I did my 60 to 80 mph 4th gear blast.
Outside Temp 65*
Updated Comp Tune on PL 8
Matted throttle
Max Boost 44psi
Max EGT 1580
Max RPM 3176
Seat of the pants PL 7 pulls just as hard but results in substantially lower EGT. I wonder if I'm at the limit for peak injection quality on PL7. PL8+ might just dribble the fuel at the end of the pulse creating extended burn well into the exhaust stroke thus higher EGTs.
Outside Temp 65*
Matted throttle
Max Boost 44psi
Max EGT 1580
Max RPM 3176
#32
#33
Well, I got to drive the truck today about 60 miles. I ran into a local guy who has a good running import & he came up behind me flying [at the local track ofcourse]. I decided to see what the new injectors had. I turned my Adrenaline to tune 1 which is the settings mentioned above [2200 fuel stretch etc.] I never got my truck out of 4th gear, just held it in 4th & hammered down before coming up on a turn. I checked my data logger when I got home. Very hot injectors!!!!
Speed 96
rpm 4081
EGT 1832
boost 54
Speed 96
rpm 4081
EGT 1832
boost 54
#35
I tried running it today with the fuel stretch turned down to 1800 & timing 7 & egts didn't go over 1500 at any rpm. Didn't feel as strong either though. I never took Smarty off the truck yet, still stacking it.
#36
I think u are gonna be in the 525hp range with your setup. Getblown5.9 had a silver bullet 66 charger with mach 7s and some ddp 250's and laid down 581 with the mach 7's and like 570 with the ddp's. I think he had the tst comp and smarty at the time. A 64 or 66 charger would help you out a bunch I bet.
Im kinda anxious to see what a redline box will do on these trucks compared to the other boxes and stacks also.
#37
#38
i cant believe some of the egt numbers you guys are seein, i ran a duramax one night and seen egts at 1800 and 3600rpm, but thats probably because of the stock turbo.
#39
Just for a comparison, tonight I put the Adrenaline back in and with the comp tune on level 10 on the way home I had a Duramax tailing me so I couldn't resist. A good pull in 5th gave me
Speed 110
rpm 3300
EGT 1350
boost 54
backdown 65%
Had the defueling set to 55psi and the truck was defueling bad I think I need to adjust my wastegate I don't know what it would climb to but it gets up there pretty fast. I really don't feel like doing another headgasket yet.
For an comparison to the Edge/Juice on level 6 to to the comp tune on level 10, the Adr. isn't alot more powerful but you can feel a difference. The biggest difference is that the Adr. seems to keep fueling were the edge seems to stop around 3000rpm. I have to be careful in second when you get on it and it climbs to 2000rpm then almost instantly your at 3500rpm. Way to much torque on the driveline.
I will have to try your custom tuning next and see how that works.
Speed 110
rpm 3300
EGT 1350
boost 54
backdown 65%
#41
Speed 110
rpm 3300
EGT 1350
boost 54
backdown 65%
Speed 110
rpm 3300
EGT 1350
boost 54
backdown 65%
#42
The Guru
Time to put in some bigger sticks. Its go big or go home. 5's and 6's are nice city drivers haulers. If you truck is set-up right, you should only get a small haze on intial spool-up and some hazing at wot. Of course you need air. I can only pull around 1300 to 1400 with mine smallish sticks. The DDP's 250 are bigger and make more smoke/egt's and power but very streetable. The most my truck put down on a dyno was 677rwhp run at PDR, of course with a fresh SO VP under the hood. Of course a cam and ported o-ring head will help with egt's, and top end power.
#43
Speed 110
rpm 3300
EGT 1350
boost 54
backdown 65%
Speed 110
rpm 3300
EGT 1350
boost 54
backdown 65%
I still made the most power with the edge comp drag/Smarty #8 stack versus the Adrenaline. I really wish I could have tried the Adrenaline with my Mach 4's before I sold my 01' because I KNOW the Adrenaline was a way more aggressive box and cooler too. Man I miss that truck and Adrenaline...
Anyways, the Macher's are the ticket baby!!!
#44
Yeah I wont be selling my Edge yet but this Adrenaline sure has alot more midrange power it spools the turbo alot easier, and I love the high idle. But I think I need to adjust my waste gate I am hitting over 50psi on level 5, I wish I knew what I was getting with the Edge but it stopped reading at 45psi.
Sorry it seems like I am hijacking this thread but I guess we all got sorta similar setups so I hope it's all relevant.
JLent do you get any turbo surge? It seems like I either need to accelerate slowly or WOT if I get on it alittle and then off a bit I start getting wicked turbo surging.
#45
