Fire-ringing vs. o-ringing...
Old 05-04-2004, 10:04 PM
drawson's Avatar
Here is a pic of the set up I'm using on my rebuild The inside groove matchs the o-ring in my new PDr port and o-ringed head.
This isn't my idea but one of the great ideas to come from the late great Nowel(HVAC).
Maddog ran something real close to this all last year with out a failure at 100 psi
Old 05-05-2004, 11:58 AM
GO 4LO's Avatar
So is that a double o-ring setup or a combination o-ring/fire-ring setup? Are both the block and head cut?
Chris
Old 05-05-2004, 12:22 PM
John DiMartino's Avatar
drawson,please do tell! .im yankin the engine this week,the 14mm studds are here(thanks to Haisley and Advanced diesel).
Old 05-05-2004, 03:21 PM
drawson's Avatar
Here is how it works the outer o-ring in the block just pushes up against the head flat surface and the inner groove is a reciver groove that matches the o-ring Pier put in my head head. So the o-ring in the head pushes the copper head down into the reciever groove. I wish I could draw it so that you could see it. Nowel first drew it for me on a napkin at a steak house in Idaho.
Madddog was the same except he had a small reciver groove in the head to match the block o-ring...
Hopefully this helps...
Old 05-05-2004, 03:25 PM
BigBlue's Avatar
Nice. I don't think you'll have a problem sealing with that combo.
Bswope
15
03-30-2008 05:47 PM
Puke
05-08-2007 10:04 PM
pianotom
06-15-2005 03:34 PM
swank
11-24-2004 08:25 AM
TXram
11-08-2004 08:15 PM
Quick Reply: Fire-ringing vs. o-ringing...
