Finally finished with ISSPRO gauges
Originally Posted by sadlerb_98
I'm starting to notice black exhaust marks on the pyro probe. Is that normal? It seems to be in there pretty good.
thanks,
Bob
thanks,
Bob
P.J.
I just got home from work and tried it. I held the bottom and backed the compression nut all the way off. The pyro tube would not budge. I couldn't raise it or lower it. So, I put some more anti-seize on the compression nut and tightened it until I won't move anymore. The pyro tube will still move ever so slightly(barely) inside of the compression nut.
If that is the only problem I have with this setup, then it was worth saving the $400 doing the install myself.
Thanks,
Bob
Thanks,
Bob
solostyle1
16
08-26-2007 10:57 PM
SmokenRam
45
02-14-2006 08:57 PM
mcevins
14
05-04-2004 03:44 PM
