Faster turbo spool?
Old 04-18-2006 | 12:52 PM
24v's Avatar
24v
Faster turbo spool?
Is there anything I can do to make my stock turbo spool faster on the bottom end? To me, it seem sluggish up to about 10psi boost.
Old 04-18-2006 | 01:06 PM
abc4yew's Avatar
Yep, Get a Smarty!!!! I can't wait till they make one for my truck. ks
Old 04-18-2006 | 01:12 PM
graphitecumnz's Avatar
Smarty will take care of that but with your mods, you might want to consider getting a bigger turbo. You should be well past the limits of the stock HX-35.
Old 04-18-2006 | 02:04 PM
24v's Avatar
24v
What turbo should I be looking at?
Old 04-18-2006 | 02:43 PM
getblown5.9's Avatar
you can get one at www.puredieselpower.com
he also sells larger turbos as well!
Old 04-18-2006 | 06:58 PM
complicated question... what is your ultimate goal for the truck? are you still in search of more power? you'd certainly want to get a turbo that was either upgradeable or big enough for where you want to be. are you after quick spool with good street manners? you could be looking at something that won't support a lot of horsepower but will meet the other criteria.
Old 04-19-2006 | 12:25 AM
Ph4tty's Avatar
Look at Doug's page- he's got them all + he's a forum member and a good guy http://www.performancedieselwarehouse.com/953154.html
How much fuel does your box/ injectors add?
Old 04-19-2006 | 11:43 AM
24v's Avatar
24v
More power would be a plus...but I don't need it. I just want a little faster spool from a stop. I pull a 5th wheel, racecar trailer and a boat with it so it needs to be a good option for the mod's I have to make a good towing combo.
Old 04-19-2006 | 12:28 PM
Ph4tty's Avatar
Well if thats the case then let me change my answer. Smarty makes turbos like to spin
Old 04-19-2006 | 02:48 PM
HOHN's Avatar
My combo of Smarty and M4s produces essentially ZERO lag with the stock turbo.
That said, this turbo is too small, so I'm getting a leg benefit that is misleading. A real turbo would have at least a little more lag that this setup.
Still, I never find myself wishing the turbo would spool. It's nearly instantaneous.
Old 04-19-2006 | 04:15 PM
24v's Avatar
24v
So the Smarty is the answer rather than turbo? Either way....it aint cheap.
Old 04-19-2006 | 04:30 PM
HOHN's Avatar
Since your original question is about increasing spoolup under 10psi or so, I'd say that the Smarty is your best bet.
See if you can't find a way to get a demo or test drive to see if it delivers what you are looking for.
I dare you to try it and not buy
Old 04-19-2006 | 04:49 PM
24v's Avatar
24v
It's OK to dare me.....just don't double dog dare me.
I don't know anyone in this neck of the woods who would have a Smarty.
Hmmmm.....maybe I could sell my DDTTPM to my bro-in-law and put some more with it to get the Smarty. I wouldn't need the DDTTPM with the Smarty would I?
Old 04-19-2006 | 05:19 PM
RowJ's Avatar
Might help if you let us know where you are ? Maybe someone will offer a Smarty Test.
RJ
Old 04-19-2006 | 05:49 PM
24v's Avatar
24v
Sorry...just updated profile. I'm in Woodstock, AL.
Quick Reply: Faster turbo spool?
