Fass/Vulcan questions
Old 03-07-2006 | 08:39 AM
Pike's Avatar
What is the difference between the small fass that just looks like the fuel pump and the other one with the pump on top mounted horizontally with the 2 filters below it?
Does vulcan make a big line kit that doesn't move the transfer pump, and how effective is that kit? We are in salt country, and I don't want it on the frame rail. Thanks
Old 03-07-2006 | 09:06 AM
RickCJ's Avatar
FASS is (Fuel Air Seperator System) this is with the filters! The fuel pump without the filters is just a pump, FASS II. Both the FASS and FASS II come with big line kit!
The pump should be mounted as close to the fuel tank as possible! Salt will get on the pump no matter where it's mounted! Engine or frame.
Old 03-07-2006 | 12:14 PM
Big Smoky's Avatar
So both the FASS 1&2 come with the big line kit? Is it the kit that replaces the banjo bolts too? Thanks
Eric
Old 03-07-2006 | 08:32 PM
HP Upgrades's Avatar
Yes they come with everything for a complete installation. I have a pdf file with installation instruction from DPP the makers of the FASS system. Let me know if you need it and I will send you a copy. It has a parts breakdown included. We can get you the pump or system too if you need.
smokinram99
21
11-07-2008 12:26 PM
Coaldigger
04-10-2008 11:49 PM
sluggo42
03-14-2007 09:05 PM
Kevins
03-30-2005 07:43 PM
