Fass system
Fass system
Just ordered fass system from extremdiesel was wondering what I need thats not included in the kit? Fuel lines and fittings and such. Do you remove the factory lp and filter or bypass or what?
Kit has everything you need. If you got the fass II then you can upgrade the line from the stock filter to the VP44, then you would require a few more fittings. I did not do this and I don't think it's necessary unless you have more than 400 hp. I see 17 psi @idle and never goes below 14.5 @wot. Fuel pressure guage becomes a bore when you go fass, that's a good thing right?
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
BCarmicle
13
11-07-2005 04:20 PM
Flatty
04-25-2005 12:49 PM
