FASS solves the Lift Pump/VT44 Problems?
So I am still researching what truck to buy and it seems that the 24V might be the way to go as they are more plentiful in Southern California and are in better shape.
So I have discovered this whole FASS kit and I have a simple question. Does it basically solve a lot of the problems encountered with the Lift Pump / VT44? It seems the Lift Pump is prone to failure which results in fuel starvation to the VT44 which causes it to overheat and eventually die. The FASS system seems to be a durable method to supply constant fuel pressure and solve the issues. Is this a correct summation? If so then buying a 98.5+ and immediately installing the FASS and a proper fuel pressure kit should be a good step towards reliability.... Thanks for any help you can provide.
Mark
Mark
Yes a FASS system would be a great idea it should override the LP. 24 Valves are great motors with there week link just like anything else. It is the LP if you keep plenty of fuel to the IP you should be fine.
Re: FASS solves the Lift Pump/VT44 Problems?
Mark
Mark
Originally posted by BigBlue
VP44 longevity is a roll of the dice.
It's not like the precision engineering and quality control on the VP44 is as sloppy as the 47 RE (auto tranny), for example, where some are very good and others are weak from day one. At least I don't think it's the same because the number of problems is so much smaller.....with no clear pattern, and many guys that toast their VP44's seem to do it 2, 3, even 4 times.
Until Bosch releases their findings from failure analysis...we may never know the causes. I'm just not ready to accept that it's luck of the draw.....yet!
radelow - In my opinion, the 24v's is a great first CTD truck...with the last 2 yrs being the best (01 & 02). The FASS will solve the weak link mentioned and is a great step towards reliability...just be sure a bad lift pump was not previously ignored.
RJ
mstep3
23
07-27-2010 02:22 PM
ollie32
06-03-2007 09:29 PM
Buckshotmckee
16
02-14-2006 12:32 PM
BCarmicle
13
11-07-2005 04:20 PM
